Hey, so I'm new to having a not dogshit computer, and I'm slightly concerned about my temp readings. So for starters, I think I have a poorly seated AIO, but I'm going away for Xmas at the end of the week, and plan to just keep it as is, and reseat it when I get back and install my sleeved cables.
My concern about the CPU.
If I'm gaming, it will eventually creep up to 70-75C, and in Cinebench R20 it will go to 76C. I know that's like 20C under the max safe temp (that's why I'm not reseating right away), but it concerns me that it's never pushed over? Is it safe to say that the readings are 100% accurate and something isn't messed up?
With my GPU,
I ran Firestrike on stock settings, and I never went over 60C. I adjusted my fan curve and added +100mhz/+500mhz and never went over 45C. And my fans never went over 55%. Is that accurate? It seems oddly low. At 40% fans I idle around 28C. Is this accurate and normal?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1133437-are-my-temps-correct/
Just now, emosun said:
seems fine to me.
That’s what I thought. It just threw me that my GPU temps were so low
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120225
I think it's safe to say that these thermals are good for 240mm AIO, maybe you indeed don't have enough mounting pressure but it's not going to change much. If you're worried about accuracy of temperature readings then try HWiNFO or Ryzen Master.
Tag or quote me so i see your reply
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120226
Those are what I’m using for temps. I might try to tighten it down more. I mostly think I have a bad mount since I placed it down, the bracket got fucked, so I had to take it off, then replace it back on. And my idle seem a little high (around 40)
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120231
Nothing high here, 80° C in MT load, 60° C in ST load and 40° C idle are perfectly reasonable thermals.
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120242
Oh. Well that’s awkward. Maybe she’s good to go then haha. Thanks!!
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120252
With my GPU,
I'd question those GPU temps.  benchmarking never got above 60c?  What were you doing that didn't break 45c?
Benchmarking runs your GPU full out, should have seen temps in the 70's and possibly 80's.
Sounds like they're not reading right.  Even your idle temp is very low, that's barely above ambient for most people.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120263
Gpu load doesn’t seem right if it’s that low in real world.
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120267
That’s why I’m confused. I just ran Timespy at 1440 and MSI afterburner at +100 Core and +1350 memory and I only hit like 54C. MSI afterburner says the same. I’m in my basement and ambient is probably around 19C.
The temp was very slowly climbing, but it would cool down to low 40s quote quick since each graphics test is only about a minute and a bit, then it would slowly rise back up. HWMonitor says the same
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120282
I just explained my GPU a little more in the above post
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120284
If your ambient is that low, then things may be right.  Most people don't have a ambient that low, which would definitely help.
Temps aren't the measurement, it's the DELTA that is what is important.  With your ultra low ambient, you have more understandable deltas.
Run her for a while and see I anything changes.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120289
The DELTA? Sorry I'm new to OCing.
My ambient upstairs is 70F (21C), and my basement is cool enough I have a small space heater on the other side (15ft) and wear a hoodie. So i'd say a little cooler down here.
I'll run it for a while later and see what she hits.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120306
Delta.  Difference.
We're looking at the difference between ambient and performance temps.  If you have 19c and you idle at 28c... that's 9c of heat produced.  I ambient at 23c so a 28c idle would be 5c of heat, which would be too low IMO.
The difference in temps is the heat produced by your components and what we're need to look at.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120325
Delta.  Difference.
Ooh. Awesome. Thanks!
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1133437-are-my-temps-correct/#findComment-13120422
