Not a lack of wattage. Is your CPU shutting down from thermal limits?
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118530
That card has a minimum of 650 w power supply and it is not always good to go by the minimum. You should either buy a higher wattage power supply or tweak the settings of your components to make them draw less power. You should also see if lowering your graphics setting in the game makes a difference. Go into pc part picker, enter all your components and see what wattage you need. Hope this helped
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118539
Thanks, I would consider in another PSU, but not a the moment :)
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118542
If anything is overclocked, disable them. It could just be instability. It could also be the PSU. Not because of the wattage, but because the N1 is absolute dogshit garbage. Try replacing it with a decent 450-550W PSU.
That's a recommendation, not a minimum. The recommendation assumes a worst case scenario with a crappy PSU. If you look at how much the system actually needs, you'll find a much lower number.
The wattage calculator there is absolutely useless. For a better estimate, I recommend you go to random.org, as that will give you a more realistic value.
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118545
you got a really crappy PSU, so of course it's not gonna run well.
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118546
Not true. The 2080 draws ~ 250 watts. he still has "400" watts left. That CPU, even overclocked wont touch 100.
I dont care how much RGB they have, its not gonna draw 300watts.
3 minutes ago, Vuem2 said:
How can I prevent this?
Download aida64. Run the stress test. If your temps exceed 80c, you have a cooling issue. I would suggest reinstalling your CPU cooler and seeing if the issue persists.
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118556
Evga says that the minimum is a 650 watt power supply. It might only draw 250 watts but evga says that it is the minimum for the entire system.
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118559
It doesn't matter what EVGA says about a minimum recommended PSU. Those numbers are VERY conservative and you should do your OWN calculations, and then add ~ 25%.
I could run two 2080's in SLI with a 3900x on a 750watt psu and everything would be fine.
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118566
Thanks, I would look into it
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118576
I ran the aida64, here is the result. I still use stock cooler from ryzen 5 2600, but I replaced the pre-applied thermal pastes with the Noctua NT-H1 paste.
How can I prevent this? buying an after market cooler?
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118611
Is your CPU overclocked? Those temps look high even for the OEM cooler... it should idle in the mid 30's. Try re-installing your CPU cooler
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118621
Just re-installed the CPU cooler, this time I spread the paste evenly across the cpu heat spreader, instead of leaving a dot pattern as before.
However, the result remains the same :))
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13118725
20 hours ago, GoldenLag said:
The PSU is garbo. That is why its shutting down.
Or at least most likely considering what PSU it is
Haha, garbo, that is so Australian, LOL. (no offence)
I will replace it with a 80 Plus Gold just to be sure.
Thanks bro
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13121539
Thanks bro
Please actually tell us which PSU.
Because 80+ gold is an efficiency rating. Nothing more. Doesnt say how good the PSU actually is
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13121834
The PSU I am using now is one.
https://www.evga.com/products/product.aspx?pn=100-N1-0650-L1
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13123701
Just now, Vuem2 said:
I am not sure, any suggestion?
May be this one:
https://www.evga.com/products/product.aspx?pn=100-GD-0700-V1
pick something from tier B or higher.
The EVGA GD is fine, but its not great. would look at the cx550, pure power 11 600w, TX550m, Bitfenix formula gold 550w over that one.
https://linustechtips.com/topic/1133233-not-enough-power/#findComment-13123732
