Got some 5v contraption with wd2812b LED’s set up.
i want to power it from my power supply/computer. It pulls about 3.5amp at MAX (all white).
i want it to turn on when my pc does. Possibly if I could isolate it and then it off when my pc is on that would be cool.
idk how to do it help would be great thanks.
https://linustechtips.com/topic/1132152-5v-psu-cable-rgb-led-link/
what is it? is it argb or rgb? better info is need thx
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
literally just a 5v connection into that white box.
Anyway its all sorted, im gonna buy a sata to molex adapter and cut up the molex adapter and use the 5v from that. They can do 5 amps on each rail so should be all good.
