Case and gpu compatiblity?
Go to solution Solved by TVwazhere,
On 12/6/2019 at 3:52 PM, Sebastian rocks said:
Thanks. I understand.  Any suggestions for the case?
Make sure to quote or tag the person you're responding to ;)
You're going to want to look at cases like the Coolermaster Mastercase series (H500, H500P Mesh, H500M), Fractal Design Meshify S2, Phanteks Eclipse Series (P400A, P600S with front plate removed), Silverstone PM01, Or the Lian LI PC-O11Air (for this, get rid of the crappy front dust filter,the top bottom and side ones are good though)
27 minutes ago, Sebastian rocks said:
Corsair obsidian 500d se . Will it fit two msi 2080 ti gaming  x trio in nvlink without thermal throttle ?
It will physically fit the cards, but those cards dump heat like it's their full-time job. I'm not convinced the 500D is up to the task. You're going to want a mesh front panel for maximum airflow.
