Hello,
I was thinking of modding my Lian-Li PC-O11 Dynamic with a RGB Vandal switch.
I purchased this :
https://www.digikey.ca/products/en?keywords=PV6F240NN-3R1
which has an illumination voltage of  1.8, 2.8, 2.8 VDC (not sure why multiple values are listed) and a voltage rating of 48VDC. I have the Z390 Aorus Pro Wifi and after a bit of research, I'm pretty sure most motherboard RGB headers are 12V. My plan was to use one of my mobo's RGB header to power the switch's LEDs.
I also have a few resistors :
https://www.digikey.ca/product-detail/en/yageo/SQP500JB-1R0/1.0W-5-ND/18631
This is the switch's wiring diagram:
Can I just connect my LEDs to the mobo's header ?
Do I need to put resistance on those paths ?
What do I connect the negative terminal to ?
Thanks
https://linustechtips.com/topic/1131478-rgb-power-button-switch/
4 minutes ago, James Evens said:
Sounds to little.
R=U/I
U=12V-LED voltage
I= led current
U=12V-2.8V=9.2V
I_max=2A (current rating, actual current probably less)
R_min=9.2V/2A=4.6 Ohm
7 minutes ago, James Evens said:
Mobo:
+12V
RGB minus
your button:
common minus
separate +Vss LED
Here is the mobo RGB header layout :
Can't I just connect :
RGB minus (mobo, 2 to 4) to RGB (switch)
12V (mobo) to minus (switch)  with 4-5 Ohm resistance
18 hours ago, James Evens said:
and the magic smoke escapes
I guess the 2A are for the button. LED should be somewhere around 10 mA.
No. Now you reversed polarity.
How about adding some transistors or logic chips?
I tested each LED with a 9V adapter with resistor. The only way each LED turns on is with + to a LED and - to common. So this means on my motherboard, each RGB pin is a ground and the polarity is reversed. I think I get it. I'll look for a different switch or a common cathode RGB controller. Any leads on that, let me know.
On 12/6/2019 at 4:06 PM, James Evens said:
Quick sketch.
(snip)
While trying to decipher your sketch, I found this switch :
https://www.digikey.ca/product-detail/en/schurter-inc/3-101-403/486-3352-ND/7104548
Page 3 of the datasheet shows the assignment of each wire.
Wire 1 is labeled as Vin = 5 VDC...28 VDC
Wire 5 to 7 are the RGB LEDs and are labeled as LED red GND = ON Open* = OFF
This tells me this switch is a common anode switch where the RGB terminals are grounds. This matches my Mobo RGB header pinout. Also, 5 to 28 VDC illumination voltage means I wouldn't be required to reduce voltage to my switch.
Is my understanding correct ?
What should I do with wires 2, 3, 4 & 8 ?
Should I use wires 2 & 3 for power switch - & + (respectively) ?
the answer:
https://us.schurter.com/bundles/snceschurter/epim/_ProdPool_/newDS/en/typ_CPS.pdf
Interesting switch but $46.
100 kHz should be more then enoguh for a rgb mobo output.
So.... this Schurter switch is good for my application ?
3 hours ago, James Evens said:
If you can justify the price tag. Yes.
I found a cheaper option, just some lack of information on the distributor's page. Overall it's a cheap option even considering it's coming from UK. I'll call them tonight to validate they are common anode. I'll keep the thread posted.
https://www.switchelectronics.co.uk/switches/push-button-switches/vandal-resistant-switches/rgb-illuminated-vandal-resistant-switches
6 hours ago, thrasher_565 said:
Thanks, this is exactly what I'm looking for. There's even a choice of both polarities for all the color configurations. Very neat seller.
ya np. i was going to buy it and still might. if you do get it let me no how to hook it up to rgb. i have corsair ecosystem so no rgb only argb but there is a convertor to go rgb so ill have to get that costly but only option.
other option is to go aqua computer as they support corsair fans and have both rgb and argb.
They have confirmed the switches are common cathode. So no go.
I ordered them but it's a long lead time as they come from China. I'll open a new thread with the details of the mod project.
