Making a call out in port 3389 (RDP port)
19 hours ago, Seanbg said:After thought, if there was a way to connect the RDP protocol through port 443 that won’t be blocked by the firewall. Again not sure how to do that but it is an after thought.
Yep, you can change the port RDP listens to: Doc on Microsoft
The only issue, is I'm not sure how your issue connecting using RDP actually has anything to do with RDP? You should be able to just rdsserver:443?
OpenVPN is always an option, but I guarantee they'd block that too. My advice for your situation would be to try out SoftEther Azure (routing through MS Azure) if you would like to host a component yourself, but ideally ZeroTier.
ZeroTier is esspecially good because it will come up as another interface, is easy to manage, free, open source and can bypass pretty much any firewall.
If you need any help to set up any of these just hit me up anytime.
Hope this helps man.
