So i have only 20 bucks but christmas is around the corner. I don't know wether to get a laptop or Pc for gaming. And a little drawing. I'm on a budget of 950$ including accessories. My main use is to hang out with an old friend on Steam. I don't know if i should get a PC or laptop or if i should build the PC and which one should I buy. I need help. Can u please point me in the right directions. Thank you. And to mak this clear i am saving for 3-4 months and not buying a 950$ PC right now.
https://linustechtips.com/topic/1130812-i-need-help/
For $20, buy any random desktop computer on the second hand market. But keep your expectations reasonable (very low).
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1130812-i-need-help/#findComment-13099669
you only got $20 but you can spend $950 for a PC?
https://linustechtips.com/topic/1130812-i-need-help/#findComment-13099673
1 minute ago, PigPen said:
When I say i have only 20$. I mean that i have 20$ right now and im saving
Well we can't tell you what to buy unless you state your budget.
EDIT: Never mind, you just edited your post.
https://linustechtips.com/topic/1130812-i-need-help/#findComment-13099682
Just now, PigPen said:
I am saving for about 3-4 months. Im just looking for info on what to purchase.
then ask again once you've saved up the entire sum, anything we give you now will be irrelevant by then.
https://linustechtips.com/topic/1130812-i-need-help/#findComment-13099683
Use pcpartpicker, buy used parts on eBay and Craigslist, buy last gen hardware, if you aren't after playing AAA titles at 4k60 you can likely build a reasonable gaming system for $400-500 with second hand parts that would outperform a majority of $900 gaming laptops.
https://linustechtips.com/topic/1130812-i-need-help/#findComment-13099780
