12 minutes ago, Hugo.brunelle said:
Hello, I'm from Quebec in Canada and I would need some tips to overclock my ryzen 2700x on my b450 gaming pro carbon ac motherboard. Can you help me and tell me what I can do? It would help me stream and play games more efficiently.
Thank you
What kind of cooling do you have? Most 2700X can hit 4.2Ghz @ 1.4-1.425v
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1129966-need-help-to-overclock/#findComment-13093080
2 hours ago, Hugo.brunelle said:
I have a corsair Hydro Series H100i PRO.
I would try 4.1Ghz on auto voltage and see if that is stable and use Hwinfo64 and see where your voltage settles under load.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1129966-need-help-to-overclock/#findComment-13096514
