Hello everyone! I got a problem with my Ryzen 5 1600. So i overclocked it in the past on my ASUS B350-F Mainboard but i wasn't able to run it stable on 4GHz. It worked for gaming and browsing but when i started to render a video, my system just crashed so i dialed back all my adjustments but now i got into another problem. As far as i know the base clock of this chip is 3.2GHz and the normal boost clock should be 3.6GHz but when im playing games or just stress the cpu (for example with cinebench r15) the cpu only boosts to 3.4GHz. I updated my BIOS is the most recent which i could find on the ASUS Support page and i also tried to clear the CMOS by taking out the battery and later assembling it. Even after reinstalling windows on a different drive and having everything on default my cpu won't reach it's usual boost clock.
My cooler is the Wraith Prism cooler from AMD and it keeps my CPU pretty cool so i don't think it's thermal throttling (under load around 62 degrees celcius = ~143F).
i forgot to mention that before overclocking my PC behaved normal even with the normal cooler and a crappy airflow case (which i happily don't have to use anymore)
https://linustechtips.com/topic/1129948-ryzen-5-1600-behaving-weird/
What are you using to report your CPU speeds? If I'm not mistaken Task Manager does not report the CPU speed based off the very fastest core. I don't think first gen Ryzen rates the all core turbo and instead only rates the best core speed?
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | Car: 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Be Quiet! Pure Power 11 600W | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2018 Core i3 Mac mini, 128GB SSD, Intel UHD 630, 16GB DDR4 | Storage: OWC Mercury Elite Pro Quad (6TB WD Blue HDD, 12TB Seagate Barracuda, 1TB Crucial SSD, 2TB Seagate Barracuda HDD)
I use HWMonitor to report my CPU speeds
wait actually according to HWMonitor my CPU boosted once to 3.6GHz but only for 1 sec or less. When im stressing it rn it's stuck at 3392MHz
Just now, Medicate said:
3.6Ghz is only it's maximum boost clock, usually achieved when only 1 or 2 cores are being stressed. When more cores are being loaded it's normal for that processor to drop down up to 3.3Ghz
As far as i know my cpu boosted to 3.6GHz on all cores before i started overclocking so i don't understand why it's behaving like this now
It shouldn't have ever done this. The 1600 never had out of the box all core 3.6Ghz.
