Computer
Bitfenix Prodigy
Asrock z77e-itx
Intel i5 3570k
Antec kühler H2O 620
Corsair cx 500w
Crucial 8GB CL8 1600MHz Ballistix Tactical
Samsung 840 120gb
Asus GTX 660ti
Windows 8
Accessories
Qpad mk-50
Logitech g400
Logitech x-530
Steelseries sibera v2
Samsung 24" SyncMaster S24B350
20120807_134918-1.jpg?t=original&k=17cd8
20121002_144112.jpg?t=original&k=35eacaa20121002_150204.jpg?t=original&k=dc9952cImg_9730.jpg?t=original&k=d31393faNamnlos-1.png?t=original&k=50ca4dd4Img_0266.jpg?t=original&k=583ee1fbImg_0267.jpg?t=original&k=1a0438c9Img_0268.jpg?t=original&k=568c772aImg_0269.jpg?t=original&k=fd19d8d7Img_0539.jpg?t=original&k=0c928536
Img_0538.jpg?t=original&k=6f8c0f9b
I will upload pictures of my setup when my keyboard is dry and resembled.... Img_0540.jpg?t=original&k=6bfe791e
Sorry for bad English, but i try my best. ;)
https://linustechtips.com/topic/11297-simple-prodigy-build/
Amazing and the cable Management is really tidy considering there is so little space. On a  side note, isnt it not safe to open of a power supply?
As long as you dont change anything electrically, and you do it with it unplugged  i wouldn't see any risk. Its the same as messing with something inside your computer, i mean the worst it can do is smoke right?? :p
https://linustechtips.com/topic/11297-simple-prodigy-build/#findComment-120497
As long as you dont change anything electrically, and you do it with it unplugged  i wouldn't see any risk. Its the same as messing with something inside your computer, i mean the worst it can do is smoke right?? :P
Alright was thinking of changing mine after seeing this but mines hasnt really been noticeabl yet to me xD
https://linustechtips.com/topic/11297-simple-prodigy-build/#findComment-120606
Looks much cleaner than most Prodigy builds I have seen :D and I love the PSU fan mod, although was the fan loud anough for it to be worth the trouble?
The psu fan was the loudest(in idle) and it don't take that much time. The only thing to worry about is that you loose the warranty.
https://linustechtips.com/topic/11297-simple-prodigy-build/#findComment-121648
What happened to your S3? >.<
Intel i5 3570k | MSI GTX 670 Power Edition/OC SLI | Asus Sabertooth Z77 | Corsair Vengeance LP 16GB | Fractal Design Newton R2 650W | NZXT Switch 810 SE Gun Metal | BenQ 24" XL2420T 120Hz | Corsair K90  | Logitech G500 / Logtitech Performance MX | Sennheiser PC 360 | Asus Xonar DGX | NVIDIA GeForce 3D Vision 2 Wireless Kit
https://linustechtips.com/topic/11297-simple-prodigy-build/#findComment-126676
May I ask where you got the inspiration to change the fan of your power supply? :) I'm quite curious to see if my videos are having any effect.
https://linustechtips.com/topic/11297-simple-prodigy-build/#findComment-127594
Wow, good idea changing the fan to a Noctua.
Only thing I'd be a little concerned with is the capacitors in the PSU still holding a charge which can be quite bad if you touch them!
Otherwise, nice build! I love Prodigy builds to bits.
CASE: BitFenix Prodigy | CPU:  i5 4570| CPU COOLER: Noctua NH-U12s | MOTHERBOARD: Asus H87-I Plus| RAM: Muskin Blackline 8GB | SSD: Samsung 830 128gb |
SSD: Samsung 840 128gb SSD(Games) | GPU: Asus R9 270X DCUII | PSU: Seasonic 660w | MONITORS: LG 23" IPS 5ms |
https://linustechtips.com/topic/11297-simple-prodigy-build/#findComment-130675
I have dropped it, not once, not twice but many times. The drop that first cracked the screen was from maybe 2 meters right to gravel road.
On another forum! If you want to see some crazy computers go to http://www.sweclockers.com/galleri (in Swedish, but you should manage to find something)
actually i never had to touch any of the components in the psu to change the fan!
https://linustechtips.com/topic/11297-simple-prodigy-build/#findComment-130996
