Fan filters
flibberdipper
Go to solution Solved by scaryjam823,
Tell me if you can find them.
Here you go. Here is a set for my case, from what I've read they're great filters.
I just took out my grandma's HP, and took all of the cat hair out of it. I'm kinda thinking about getting some fan filter stuff for the vents, so I can cut some out and use adhesive to put it on. Any ideas?
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (9TB partition for general storage + 2TB partition for dumping ground), 4x 8TB WD White Label/Red (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
OptiPlex 7040M
Intel Core i7 6700, 2x16GB Mushkin Redline (stuck at 2133MHz CL13), 240GB Corsair MP510, 130w Dell power brick, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
Use sticky velcro pads so you can easily remove them for cleaning.
Build 1: 4770k (H100i) | 2 x MSI 280X Gaming 3G | Asus ROG Maximus VI Hero | Corsair RM850 | 16GB Corsiar Vengeance 1600MHz | Corsair Obsidian 750D |
Build 2: 3770k (Titan Fenrir Evo) | Powercool 3GB HD7970 Asus Sabertooth Z77 | Corsair TX750 | 16GB Kingston HyperX Genesis 2133MHz Inwin Fanqua |
I'd use velcro instead of adhesive.
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
for cleaning use compressed air + if you do your own cleaning using brown tape helps to remove dust from flat surfaces
unless you are using a high quality adhesive tape not glue to stick fan filters id advise with using velcro strips like @Jogostar & @Jamie suggested :D
also just buy some fans filters off ebay or something
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
Yeah, that's what I meant. :P I was thinking a big sheet of the material, and some smallish velcro that will stick to it and the side panel.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Only has a CPU fan. And it sucks dust in like CRAZY through the ventilation. I pulled 5 feet of cat hair out of the front panel.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
What are you trying to cover? Fan mounts that are empty or something else?
Honeycomb ventilation holes in the sidepanels (there aren't fans there, PC only has CPU/PSU fans). It's an HP Pavilion P7-1234, BTW.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Do it like I did with aquarium filters and white duct tape
IMG 1308
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
Ah now i see what you mean. If i were you i'd cheap out and go get some tape and cover all the holes. The PC will get enough cooling without the need ot them holes. And if you cover them up with w/e it will block 95% of the airflow anyway.
Such ghetto.
Much like.
How perform?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Such ghetto.
Much like.
How perform?
Very well.
Much flow.
Such style.
wow.
Very well.
Much flow.
Such style.
wow.
Such good.
Must have.
No link. :(
Main rig on profile
VAULT - File Server
OptiPlex 7040M
lol Bet my grandma will want to know why I want her to buy fish tank filters...
EDIT: Still gonna need velco, though... (Link please).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Y NO USE DUCT TAPE?
Y NO USE DUCT TAPE?
Granny won't let me.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Well idk where you can find velcro
Maybe Michaels:  http://www.michaels.com/Velcro%C2%AE/products-generalcrafts-brands-velcro,default,sc.html
They actually sell some custom fan filters for some cases, I can and will get some for my case. I forgot where to get them though. :(
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Oh, hell yes. THANK YOU.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
No problem, glad to help. :D
