when i create a world or even join a world i get some erally huge fps drops from 500 to 3 every second
i play every other game at medium or high settings no problem but idk whats wrong
i played it a lot and i ahve this problem lately\what should i do
is it a cache or sth problem ?
https://linustechtips.com/topic/1128109-huge-fps-drops-in-minecraft/
What's your monitor refresh rate? Try limiting your FPS down to something around double that. I used to have extremely high GPU usage and some weird issues like that, but the in-game graphic options let you set a maximum frame rate, and that worked.
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
install optifine
its 60 and its locked to 150
hmm. strange..  have never used any rtx or gtx gpu before. try this in the following order. 1. turn on fast render. fast math. smooth fps, smooth world and VBO's. if these dont work. uninstall your gpu drivers and install the latest version of the driver from nvidia's website. if you have integrated graphics. make sure that minecraft is set to use the high performance gpu. let me know how it goes.
i did all these stuff before i tested it all but those lag spikes are only on single player not on multi
and after 20 min it goes away
