Hi Everyone,
So my PC consists of
G.Skill ram, Aorus x470 Gaming Wifi 7 mobo, MSI Gaming X trio GPU, AMD Wraith Prism cooler, Thermaltake RIING Trio RGB fans and cooler master ARGB fans.
Complete List here: https://pcpartpicker.com/b/RbYTwP
Any software so I can control them all together? Many times, their separate RGB softwares, ends up conflicting each other.
https://linustechtips.com/topic/1127008-need-some-universal-rgb-syncing/
Sadly no... They all feel they need to have there own controllers and software to control it... instead of working together and getting behind 1 platform to allow the customers more choices. This is a tactic to force customers to stay inside 1 ecosystem of manufacture to get things to work together properly like this.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
9 hours ago, kirtimaan01 said:
Hi Everyone,
I think you can make the RAM work with RGB fusion - so with mobo, the thermaltake RIING stuff is also rgb fusion sync-able IF you have the controller hub, but the msi gpu will probs need its own software, and Idk about the wraith.
You should always plan ahead about software comp before building a system.
