I mean if you want a gaming headset that's focused more on having a mic, good wireless connectivity, and fancy RGB, then it's a good headset, especially for $50.
But don't get a gaming headset if you aren't using the mic, don't care for the aesthetic, or care about good audio quality.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
13 hours ago, chi_chi_ said:
Its normally 90 bucks and right now it's on Amazon for 50 so I'm considering getting it, any reviews that you guys have?
Avoid gaming headsets like the plague. Get a proper headphone and amp/dac and a separate mic. Oh, and add another zero to your budget while at it.
5 hours ago, chi_chi_ said:
@HumdrumPenguin
yeah, I would get all that but im not gonna drop that much money for one.
Just wanted to leave it on the table. I used to get all kinds of gaming branded headphones back in 2013 and before. Once you leave all that behind, you start asking yourself why wouldn't you even consider something out of the "gaming" world. I would apply the same line of thought to chairs; people going for racing chars instead of a good ergonomic one. The difference is night and day.
All of that aside, if I were to consider a gaming headphone, I would probably take a look at Razer's new models with feedback that rumbles your head or something like that. At least that's something you don't normally get. Soundwise though, I wouldn't keep hopes up.
1 minute ago, HumdrumPenguin said:
Just wanted to leave it on the table. I used to get all kinds of gaming branded headphones back in 2013 and before. Once you leave all that behind, you start asking yourself why wouldn't you even consider something out of the "gaming" world before. I would apply the same line of thought to chairs; people going for racing chars instead of a good ergonomic one. The difference is night and day.
All of that aside, if I were to consider a gaming headphone, I would probably take a look at Razer's new models with feedback that rumbles your head or something like that. At least that's something you don't normally get. Soundwise though, I wouldn't keep the hopes up. Hopefully you are not as anal as I am and will be happy with your acquisition, because that's what really matters in the end.
Not everyone wants to or can spend that. Also, an amp and DAC isn't always necessary.
