so today all of my parts came in for my new pc build and this is my first build i paired a b450m-hd’s r4.0 with a ryzen 3 2200g with 2x4gb sticks of ddr4 2666mhz and a gtx 1050 and i made sure all of the plugs were in correctly and that the header was plugged in right and all the fans run including the gpus but i still get no display please help
-Moved to Troubleshooting-
Using the APU or the GPU?
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
Try moving the display cable to the APU (the graphics port on the motherboard backplate where you find the USB ports). If that works you need to go into the UEFI/BIOS and change the primary display to denote your GTX-1050
Ryzen is usually iffy with certain types of memory. Check your Motherboard Manual or the correct placement if you haven't already. I would take out the Right stick of memory and see if it boots, if not then take it out completely and boot and try to get into the bios. then put in both sticks and it usually boots. i just worked with this certain motherboard. its wacky. also make sure your connections to your display is good
i tried this i still get no display from the gpu or the motherboard
like take out both sticks of ram and see if i can get into the bios?
Just now, carpalflower3 said:
i tried with and without the gpu
What type of cable are you using?
Just now, Budddy1 said:
Sure, then re-insert them back in (after a boot) then power off
Don't misread this.
Power your system off, change out of your memory, and then power the system on.
i tried using vga and hdmi neither game me a display
You're sure the display you're using is working right?
7 minutes ago, carpalflower3 said:
still no display
Weird. Can you list full specs?
b450m-hdv r4.0
ryzen 3 2200g
zotac gtx 1050 2gb
patriot viper elite series 2x4gb 2666 mhz
apevia astro 500w 80+ certified
and my case is a rose will fbm-x1
2 hours ago, ajenningstech said:
Are you placing the RAM in the correct slots? Some motherboards will refuse to boot unless the RAM configuration is correct.
i tried both ram sticks in each slots and even when i boot without the ram i get no post beep from the speaker so i’m starting to think i got a faulty cpu or mobo
