Phone has issues on WiFi
Hey Guys, I'm having a really bizarre issue with my smartphone...
On WiFi, some of the apps won't load, or are very slow to load content, such as photos and videos in Twitter or logging in on Minecraft Earth. While on Mobile Data, however, this problem completely disappears. I've got no idea why... any suggestions?
Phone Model: Samsung Galaxy A50
Quote this or use @BaconLord222 if you want a reply
PC Specs
Main Desktop
CPU - AMD Ryzen 5 2600X
CPU Cooler - Stock Wraith Spire thing lol
Mobo - MSI B450 Gaming Pro Carbon AC
GPU - Gigabyte GeForce RTX 2080 Super Windforce OC 8GB
RAM - Team T-Force Dark 16gb (2x8gb) 3200MHz DDR4
Storage - Corsair Force Series Mp510 240gb
                 Seagate Barracuda 3TB 7200rpm HDD
PSU - EVGA SuperNOVA G3 550W
Case - Phanteks Eclipse P300
O/S - Windows 10 Home 64bit
sounds like a QOS setting potentially on the wifi router or some type of parental controls.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
I've just quickly checked my router's settings, and I can't see any setting that could be causing a problem. What should I be looking for specifically in the router's settings?
PC Specs
Main Desktop
What is your ISP connection type? speed your suppose to be getting? Are you getting said speed. What type of wifi are you connecting to Wireless N, AC? 2.4 or 5Ghz?
Could be dropping packets, poor Wifi config, Phone issue the list goes on to get definitive answer more information is needed.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
I believe the connection type is a copper wire to somewhere, I might be wrong. The speed I'm supposed to be getting is around 100mbps, and I'm getting that. I'm using Telstra NBN (in Australia) and I'm using 5Ghz to connect.
PC Specs
Main Desktop
use fast.com from your phone on wifi and give your download, upload and latency load and unloaded.
Internet Connection
Passmark Score
3dmark Score
Network
My Speed is 45mbps (keep in mind, I may be wrong about that 100mbps speed). Latency is 7ms unloaded, 68ms loaded. Upload speed is 14mbps according to fast.com
PC Specs
Main Desktop
Doesn't look bad, im guessing by the loaded latency your on a DSL type line coaxial usually have a lower loaded latency.
Do you have a windows machine hooked up that network via wired or wireless?
Internet Connection
Passmark Score
3dmark Score
Network
I've got my windows desktop, that I'm currently typing on, on the same 5GHz network, and it works fine.  this is how it looks on fast.comHgYf5gAoP6.thumb.png.3a4d1f1ac5b30e85165d04cef535f08e.png
PC Specs
Main Desktop
Open a command prompt and run this line, send the results how many received, how many lost and min, max, avg latency
ping twitter.com -n 100
While that line is running open a second command prompt and run this line, run this trace and copy results or screenshot.
tracert twitter.com
Internet Connection
Passmark Score
3dmark Score
Network
tracert twitter.com
PC Specs
Main Desktop
Everything looks good on your ISP going out. So the issue most likely lies with the device or router config. With that being said not having the issue using mobile data lets look at your router settings. If you like to PM me to go from here that would probably be faster and easier.
Internet Connection
Passmark Score
3dmark Score
Network
One thing that I completely forgot to point out is that, for twitter anyway, if i open a tweet in the app it wont load however if I load it in my phone's browser it loads fine
PC Specs
Main Desktop
I'd be happy to continue this in PM's though
PC Specs
Main Desktop
