Sapphire Nitro + RX 5700 XT Fan Curves
Solved by BTGbullseye,
5 hours ago, Kenoxabe said:Hey guys. Just recently purchased a Sapphire Nitro + RX 5700 XT. And as I was playing SW:Jedi Fallen Order, I noticed that the temperature for my GPU was reaching 81c and my Junction Temp was reaching 97c.
You're doing way better than my reference cooler... Your junction is my regular GPU temps, and my junction is 110°-115°. Those temps are not in any way harmful to your GPU.
5 hours ago, Kenoxabe said:Is there any way to lower the temps without proper cooling?
What do you mean "without proper cooling? You already have proper cooling on it.
Yeah, but none of them are at 100% fan speed. You WILL get a temperature drop if you increase fan speed.
