No, you would have to use a meter where your pc is plugged into for total system power usage.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/112431-power-usage/#findComment-1503268
I don't think that what you want exists.
for real?! all the crap that is out there and not one on power usage! my goodness! thanks anyway
Something Awesome!
https://linustechtips.com/topic/112431-power-usage/#findComment-1503277
well you would have to have software for the psu. Now there are calculators but they are only just a rough idea.
https://linustechtips.com/topic/112431-power-usage/#findComment-1503284
Math.
V = I * R
P = V * I
V = Voltage
I = Current
R = Resistance
P = Power
Calculate it ;)
Or just use a watt meter.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/112431-power-usage/#findComment-1503422
I know right?! All the high tech things that shows your gpu, or cpu stats, none for your psu.
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/112431-power-usage/#findComment-1503499
with a corsair 750m?
Isn't there Corsairs own software for that? Something Blonk? (my early-wake-up posts are bit sarcastic) Anyway you can buy thingy that goes between wall and PSU powerplug. Thats easiest solution since you don't need to know about electrics to use it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/112431-power-usage/#findComment-1507229
