UPC For the Horde themed 750d build! LED MIDPLATE
U_P_C
10db674b-35b2-4c10-b7c0-f5cab3612899_zps
Hey LTT
thanks for stopping by my second build log!
Some of you may remember my other build.
well now I'm back at it again with the Corsair 750d!
The theme of this rig is WoW's For the Horde, as the owner loves to play WoW.
There will be a lot of customizations and some cool things here and there.
Parts:
Corsair 750d
Asus z87 Sabertooth
Asus Raidr
Evga 780ti
intel 4770k
hybrid hdd
silverstone 1200 watt
16gb g.skill 1600 ram
corsair h110
We will be doing full custom loop h2o eventually. The h110 will serve our purposes just fine for now
let the fun commence !
Tag for the fun!
Looks promising, but the effects in the last photo make it look like the cover of a bad 70's porno.
"M. Aronnax." replied the Canadian, "your arguments are rotten at the foundation. You speak in the future, 'We shall be there! we shall be here!' I speak in the present, 'We are here, and we must profit by it.'"
Im in man. Looks nice!
  • CPU : i7-4770k, Mobo: ASUS Maximus VI Gene, RAM: 16gb G-Skill Sniper 1866, GPU: ASUS GTX780 DirectCUII, Case: Corsair 350D, Storage: Samsung 840 EVO 250GB & Seagate 1TB HDD, PSU: Seasonic 860w Platinum, Monitor: ASUS VN-247P, CPU Cooler: Custom Watercooling Loop, Mouse: Steel Series Sensai Raw, Sounds: Vmoda Crossfade LP
    Build Log: http://linustechtips.com/main/topic/112285-slightly-smaller-just-as-baller/
Tag for the fun!
Excited already :D
It'll be promising! Can't wait to post more pix
Posted Image
Subbed!
Haha but those were the best!
Thanks!
One thing I will say, though, you shouldn't of gone with a 1200w PSU as it will never reach it's full efficiency! You should of gone for something like an AX860i (Which is plenty enough to run a water loop, 2 680's-oc'd- and an i7 4770k-oc'd) Then the PC would be at about 50% power when on load and it's efficiency would be a lot higher than this.
when overclocked and under loop, i guess it would pull... 500? should check internetz
Not even that dude, overclocked no loop with 99% load on cpu and gpu (2 680's and a 4770k) it only pulls about 350w, so the loop MIGHT add like 50w? So yeh 1200w is completely wasted here tbh.
We wanted to future proof it, it was also a great deal and cheaper than some 1000w, plus we chose this psu for sleeving because there is only 1 double wire and all others are 1:1.
And from personal experience, when benching on custom bios my two titans shut down my 1200w psu
in case any one couldnt figure it out. its a red themed 780ti !
59C63973-7B58-4BF5-ADB4-8CE74FB992AE_zps
turned out great!
the logo also came in, and no time was wasted
The next step is to make the light box.
Now in my 900d, i had the luxury of having a little shelf so to speak already in the case. this provided me with enough of a lip for my plate to rest on easily.
the 750d doesnt have that option.
so i had to make a shield.
The led light box follows my standard format. aluminum construction, plexiglass, and leds!
wired it up to test anddddd success!
thats it for now
Thanks!
Well this will be the final update until funds come in for the h2o gear! but being that it is the last update it is a big one!
now that we know the psu shield/shelf works, and that the LED midplate works, it was time to sleeve!
We continued to use the red/black theme and had a sleeveathon! between the both of us sleeving, making wires, and making sure it was perfect it took us about 8 hours. I had to train my associate in the process.
i knew this was going to be a while, so i brought out my trusty work bench... the OFFICIAL Beer Pong table =) and cracked a few beers.
13DDF8D7-3A66-4878-A485-E1D0437F7A9F_zps
The end results are nothing short of perfect!
Thanks for viewing, UPC will be back with more!
Very nice :)
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
its alive!
pUT A WHITE LED ON TOP? NO? :D
turned out great!
thats it for now
Thanks!
LOK'TAR FRIEND
