why not go for the 5700xt if you plan to spend that much?
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
Thanks just must have missed it which monitor do you recommend for the updated:
That cpu cooler on ryzen 9 3900x is not good.
What you use this pc for? for gaming ryzen 9 with 5700xt is overkill, ryzen 7 does the job.
And that msi mech 5700 Xt has bad cooling, this power colors one better
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
You cant really get better system for less than this, well you can cheap out with psu and only get 1tb ssd and hdd, but not recommended.
And ryzen 9 requires beefy cooler, hyper 212 black edition not enough
Just a thought. Id dont really know how well a Hyper 212 cools but according to reviews (H@r*wa*e Un**ed) the performance of the third gen ryzen will heavily rely on the cooling. cooler CPU = higher boost clocks. so i think the hyper 212 is not enough(for performance reasons ) for a 3900x
CURRENT PC SPECS
1 minute ago, upgradability said:
I plan to put a mild oc on cpu. utilizing it mostly for handbrake and trancoding- compiling and decompiling.
u wont even make a mild oc on the cpu, thoes chips already have trouble reaching their boosting speed, with insane voltages
12 minutes ago, upgradability said:
Got a solution for that?
nah its just the chips are already running at its limit on stock +-,  should be happy if u even reach boost clocks xD   u need some decent ocoling for that tho
Going with https://pcpartpicker.com/product/kTL7YJ/nzxt-kraken-x52-rev-2-731-cfm-liquid-cpu-cooler-rl-krx52-02 should that be enough
Just watched that review of the Aussie. GD that thing uses a load of ?
and that is why even on my 3600, i used a 250W tdp rated cpu cooler as seen on my sig :P
CURRENT PC SPECS
