Razer Blade 14 networking issues
25 minutes ago, blergous said:I'm not sure how to do it and would appreciate some guidance or advice as I am not incredibly technically proficient
Laptop WiFi adapters are in a M.2 format like SSD's. Only the slot used for storage and used for WiFi are keyed diffrently. The biggest issue you might have if Razer white lists cards in the BIOS. If they do that then only the cards on the White List will work. So you will have to research what cards people have gotten to work. Intel based WiFi adapters tend to be the better ones however.
26 minutes ago, blergous said:Switching to Linux isn't really an option IMO
Never said swtich. I said try a Live CD. Which is bootable verson that runs off a CD or Flash Drive. As I said this takes Windows out of the equation. Because if it works in Linux then its a Windows Issue. If you determine Windows is the issue then you can attempt to reinstall the OS, some times that solves the issue.
28 minutes ago, blergous said:As for my ISP, i'm really not sure. Can you help me understand how to check? I've never really interacted with my ISP as far as i'm aware.
Well it depends what kind of Internet you have. Me I have Cable (coax) thru Comcast. So if you have the same type of internet as me I can help. If you have any type of DSL I wont be much help.
