Low pitch humming noise from new PC
32 minutes ago, LIGISTX said:Hmm, could be PSU or Mobo as well. Try and see if you can tell where it is coming from.
Think I found the source of the sound, the top chassis fan is spinning like a god damn blender and with the case I'm using (NZXT H500), the vibration caused by the fan is spreading through the thin top panel of the case.
If I place an object or my hand on the top panel, it becomes noticeably quieter and u can barely hear it, after removing said object, the hum returns.
I did go into bios and see what as the RPM of that particular fan and it was at 1800. Changed it to silent mode (1300RPM) and noise is lower but still not as good as having something pressing on the top panel.
Guess the last resort could be I lower the speed even further manually if it bothers me enough, otherwise should be ok.
