Ok so basically im gonna build an pc, and i dont know what gpu and psu i should buy (gpu max price around 240) and one possibility is the upcoming gtx 1650 super.
Here is the components
Asrock b450 r.4 hdv
Ryzen 5 2600
Gigabyte 128gb m.2 ssd
Seagate barracuda 1tb
Kolink stronghold
https://linustechtips.com/topic/1123358-needing-help/
You wont find much within your GPU pricepoint, so a 1650/1650 super would fit the bill just fine. PSU wise, you could go with a 500w or a 650w, 650 being a little overkill. plenty of options there. I like Corsair personally, but Seasonic and EVGA also have great power supplies at a very reasonable price.
CPU: Ryzen 7 5800X GPU: Sapphire Pulse RX 9070XT Motherboard: Asus ROG Strix X470-F RAM: Corsair 32GB Vengeance 3600Mhz PSU: Corsair RM850X White
Cooling: Corsair H115i RGB Storage: Samsung 970 Evo NVME (2TB) Case: NZXT H500i White
Keyboard: Corsair K70 Mechanical Mouse: Logitech Superlight 2
https://linustechtips.com/topic/1123358-needing-help/#findComment-13043848
Asrock b450 r.4 hdv
Ryzen 5 2600
Kolink stronghold
You can look for used and get something like a Vega 56 or a GTX 1070.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1123358-needing-help/#findComment-13044353
A used Vega 56 would probably just barely cone in at that price, and that's massively better than the 1600's.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1123358-needing-help/#findComment-13047233
Asrock b450 r.4 hdv
Ryzen 5 2600
Kolink stronghold
Do not get a video card with a 50 in it. The cpu is fine.  Very middle of the road right now. A quad core might give you the same performance, and you could probably skimp on the motherboard a little. The ssd is 1 size too small. go with a 240gb ssd. 1tb is fine,  but try to go bigger as well. Look on Ebay. Amd can never hold value like intel for some odd reason. Haswell has better used value than ryzen.
https://linustechtips.com/topic/1123358-needing-help/#findComment-13053164
2 hours ago, Kkilpi said:
What if its used in mining rig or something?
Depends on the price, the cooler attached, and what power level settings were used. If it was undervolted and underclocked, then it's probably fine to go with it.
https://linustechtips.com/topic/1123358-needing-help/#findComment-13053189
Hi, so im planning to play E sports games with this, and the 1650 super is rumoured to beat gtx 1060 6gb, and the super will have gddr6 memory, so i think it will be good enough for low settings - 144fps gameplay, but thanks though, and you can help me more with anything you want to
https://linustechtips.com/topic/1123358-needing-help/#findComment-13059678
A 1650 super better be better than a 1060. The only problem is the 1060 has more ram, and newer games, and their updates want more dedicated video ram. They're also both gtx. You want rtx if you're buying now.  Unless you call it a budget rig. Then slap in whatever. The new jungle level on csgo is heavy on the gpu.
https://linustechtips.com/topic/1123358-needing-help/#findComment-13060356
Yea i know, but the 1650 super will have gddr6 instead of gddr5 so its gonna be better, and also i play e sports games low settings you know and budget gamer i am
https://linustechtips.com/topic/1123358-needing-help/#findComment-13065564
43 minutes ago, Harry Voyager said:
On the harddrive, check the prices on Intel 660p M.2 drives in your size range. You may be able to get a 512Gb or 1TB one for the price you're paying for the 128 M.2 and TB HDD, and it will perform as well as the SSD you were looking at.
I previously had an intel 660p 512gb in this list, but i thought it was too small, and i found an 240gb wd green m.2 ssd for cheaper than the gigabyte 128gb
https://linustechtips.com/topic/1123358-needing-help/#findComment-13065711
Try to spring for the 1660. You'll be much happier, and 50s don't have good resale value. Ive got a gtx 645 in an old phenom 2 x4 955 rig i haven't decommissioned yet, and i wish i went for the 60 years back. I would have probably used it longer and my current setup would have been better. Timing on tech is everything.
https://linustechtips.com/topic/1123358-needing-help/#findComment-13068410
A 1660, used 1660 Ti, used 1070, used Vega 56, used GTX 1080 if you can snag one for around $225-250, all excellent options.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1123358-needing-help/#findComment-13068420
