Uhm the connectors in your hand are the front panel connectors. they go on a different but similar looking connector non the board.
look again in the manual, should be in there
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
Yeah was thinking that. Connectors made no sense with the manual.
just look at this and find it for me.
Bottom left of the picture.
What you showed in the original post of this thread was the connector for the audio connector. Those little connectors go into the ports in the bottom left of the picture.
Just make not of the + and - of the HDD LED and Power LED, otherwise just plug the cables in the right ports.
bro. i already plugged the connectors on the bottom left picture.
I plugged the H.D.D. Power, Power Switch and Reset Switch.
This should help:
https://www.hardwaresecrets.com/installing-frontal-audio-plugs/
