System:
2070 super Zotac AMP! Extreme
My case: Fractal Design Meshify C
Airflow: 2x 140 mm intake Noctua fans, 2x exhaust 120mm fans
CPU Cooler: Dark Rock Pro 4
CPU: Ryzen 7 3700X
Mobo: Asus x570 Tuf
Temps:
Temps while gaming were around 70-72 C.
idle temps on GPU: 31 C
load temps before undervolting: 71 C (1068 V at 2055 Mhz)
load temps after undervolting: 63 C (1000V at 2055 MHz)
So I'm a bit uncertain if I did everything correctly. Basically what I did was:
1. Check my max MHz and V under load on GPUZ and/or HWMonitor
2. Open MSI Afterburner and under settings check every box under compatibility properties to enable voltage monitoring
3. Press ctrl + F and select a desired voltage and drag it to the max MHz level seen in previous load testing (mine was 2055 MHz)
4. Press L to lock it
5. Run tests to see if it is stable
6. Unlock the point after confirming that it's stable and save the profile on MSI Afterburner
My questions:
1. Did I do everything correctly? Will the MSI profile load itself every time I start windows?
2. Are my results alright?
3. Should the curve be flat after the point that I locked then unlocked?
4. If I want to improve the performance, is it OK to overclock my GPU after I "undervolted" it? (I'm aware I'll get worse results than straight OCing it) How should I proceed doing that?
Edited by Anon7mous
spelling and added a questions
