RGB lighting for a pc case
Go to solution Solved by W-L,
21 minutes ago, paprikman said:
Hi everyone!
Since I've ordered a new pc case (define mini c tg) couple days ago and I have a mobo that supports some led stuff (asus b360-g rog), I was wondering what led strip I can buy for that system.
I feel like 1 piece of led strip at the top case border would be enough for me.
What are the options? Do all of them have same connectors? What to look for when buying those led strips? I was never interested in this before, but my research didn't give me any particular info.
Thanks!
That board uses a 4 pin RGB header so any selection of the analog series such as this will work:
https://cablemod.com/product/cablemod-widebeam-foam-rgb-led-strip-30cm/
https://www.amazon.com/DEEPCOOL-Controlled-Header-Motherboard-Devices/dp/B07GRHSS1V
-Moved to Modding Section-
Hi everyone!
Thanks!
https://linustechtips.com/topic/1121725-rgb-lighting-for-a-pc-case/
Hi everyone!
Thanks!
Thanks a lot!
