First timer here, I don't know what to do and what to buy. I'm new to this kinda thing and have no any experience whatsoever, and need a suggestion on what to buy.
I'm looking for a not so expensive parts and works perfectly fine for Overwatch and streaming. My budget is around 1.000 - 1.500 Euro.
Thank you in advance people from the internet :)
https://linustechtips.com/topic/1120434-help-me-choose-a-part-for-my-pc-thanks/
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($326.89 @ OutletPC)
Motherboard: Gigabyte X570 GAMING X ATX AM4 Motherboard  ($169.99 @ Newegg)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory  ($99.99 @ Amazon)
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive  ($89.99 @ Amazon)
Storage: Hitachi Ultrastar 7K4000 4 TB 3.5" 7200RPM Internal Hard Drive
Video Card: NVIDIA GeForce RTX 2080 SUPER 8 GB Video Card  ($699.99 @ Best Buy)
Case: Cougar MX330 ATX Mid Tower Case  ($44.00 @ B&H)
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($69.88 @ OutletPC)
Total: $1500.73
Generated by PCPartPicker 2019-11-04 15:22 EST-0500
@SupaKomputa why x570? its useless for the parts you are adding. why reference gpu? that power supply seems wayyyy overpriced. also, this needs to be euro not usd with netherland prices
Edited by Saksham
Why not? For $1500 it's ok i think, it;s only $160. I can give you a better priced list, i just want to match op budget. For Euro just times 0.9. Reference gpu just a random pick.
Here you go you’ll be probably set for a few years, besides adding storage or if your demands change
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
