[Troubleshooting] Electric shock felt from inside PC case. Could this damage components?
Hi! Just built a new PC yesterday. I shut it off today and tried to look inside to have one more look at the wiring. I turned off the PC fully but forgot to flick off the switch on the PSU. I opened the panel, touched the bottom shroud, and was greeted by an electric shock that wasn't all that painful. It felt like a ripple. I read that this may be because of grounding issues. Would my exposure to that shock cause any damage to the components of my computer?
It's working well and I'm using it to post this. The motherboard is also completely supported by standoffs, so no contacts are touching the case. I just want to make sure if that encounter caused any hidden problems down the line. Thanks in advance for your replies!
Are you sure it wasn't you who was electrically charged?
If it wasn't you, you should check your sockets, wall plugs, extension cord etc. Get an electrician to do it if you're not familliar with using a multimeter. Or get something like https://www.google.com/search?q=socket+tester&sxsrf=ACYBGNQCdIInHWEWHIc8FRCiYnlXS75GaA:1572874536809&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjquaug1tDlAhXFxqQKHQEUC3MQ_AUIEigB&biw=1920&bih=937
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
3 minutes ago, glenalz81 said:
Does your PC case have an acrylic window?
Tempered glass that's clear as day. But  I wanted to go in for a closer look, as my fans don't have LEDs and I wanted to see if any contacts were showing.
I think so. I may need to consult an electrician to see if there's any way to ground the sockets in my home. Do you think this would do any damage to the components, though?
2 minutes ago, glenalz81 said:
Most likely just earthing a static charge from yourself, grounded via the case. Components should be fine.
Will take this into consideration. Thank you for replying to the post. :D
If there's voltage on the ground wire that gets transferred to the PSU and thus the case, that is very risky to use. I would recommend not using it that way.
If this is the case, does it mean that it's been discharging electricity to everything that touches the case? Even before I touched it? Thanks!
Also, I think our sockets don't even have grounding. It's just two prongs.
Right.
Let an electrician do the wiring, you need to have gnd for the PC.
Agree with this; most likely what happened.
@Fourple
Any chance you were wearing socks and have carpet at home?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
@Fourple
Nope! It's actually quite hot where I live so I was just  wearing shorts, a tank top, and some rubber slippers.
where do you live?
In europe, we also only use 2 prongs. Depending what you are plugging into the socket (what device), depends if the device is grounded. A phone charger is not grounded, a PC power cable is (fat plugs)
Image result for EU socket examples
Image result for EU socket grounding
1 minute ago, Stormseeker9 said:
where do you live?
The Philippines and our house was built in the 80s, I think. The wiring hasn't been updated in ages. And no, our sockets do not look like that. They're type As, I think. Reference photo below.
Ah okay, i'm not familiar with how it works in the philipines
Just now, Fourple said:
I think that we just don't have grounding in our outlets.
I hope at least your house is grounded with a copper pole into the ground somewhere around the house. You'd be fucked otherwise
Will definitely have an electrician look at it. I think we have a grounding pole on our front yard. I have no idea why it's not being utilized, though.
