I no longer have the option to multi quote.
Firefox, Windows 10 latest update (if it matters).
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1117572-multi-quote-gone/
4 minutes ago, colonel_mortis said:
Is it just one topic, or has it disappeared everywhere?
Everywhere.
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998365
its there for me. This is on Chrome, will check Firefox.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998366
Can confirm that the feature's there for me on Vivaldi.
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998368
1 minute ago, dizmo said:
Everywhere.
Here on Firefox as well. On version 70.0, the latest build.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998369
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998372
Just now, colonel_mortis said:
Can you press F12 to open the developer tools, and switch to the Console tab, then post a screenshot of it when viewing a topic where multiquote isn't there (this topic would be a good example)?
Did the one above with the snip tool suffice or does it have to be that way?
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998374
I need to see the developer console data to be able to look into this.
Also, do you have any browser extensions enabled?
HTTP/2 203
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998381
Would I have to disable content blocking? It doesn't look like the console tab really has anything in it.
No, I don't use extensions.
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998385
It's there for me in Firefox 70 with ublock origin and "strict" tracking protection, as well as some other what should be irrelevant extensions
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998391
You can try disabling content blocking - it is definitely possible that it's causing issues.
HTTP/2 203
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998393
I don't think it would be, it's been on since whenever they enabled it by default in Firefox.
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998398
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998402
They make changes to the blocked list regularly, and there was a new Firefox release in the past week, so it's entirely possible that the issue could have been introduced recently. You can turn off content blocking temporarily for ltt only by clicking the shield/padlock in the address bar and clicking the relevant button there.
Can you also tell me what output you get if you paste the following into the Developer Console (while viewing this topic) and press enter?
ips.controller.isRegistered("core.front.core.commentFeed")
HTTP/2 203
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998410
True.
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998429
What about
$('[data-controller*="core.front.core.commentFeed"] [data-action="multiQuoteComment"]').show()
And does that do anything to the multiquote buttons?
That brought them back.
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998450
35 minutes ago, colonel_mortis said:
What about
But only back for a moment lol
I'll just come back the forum in a couple days and hope it's sorted itself.
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998505
Only for a moment, or only until you refreshed the page or loaded a different page?
HTTP/2 203
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998507
Disappeared with refresh/loading a different page.
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-12998514
10 minutes ago, colonel_mortis said:
Is this still happening, and if so does it also happen on non-forum content like
(should be a + to the left of the quote button on the comments)?
It was back earlier today, but it's gone again, both in the threads and that content.
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-13003667
I noticed it happen for me earlier today while the page was loading, but after a few seconds they showed up as they should.
https://linustechtips.com/topic/1117572-multi-quote-gone/#findComment-13003670
