Hi! First time posting here! Lemme get straight to the point.
So, I have a Lenovo Legion Y720, I7 7700HQ, GTX 1060 6Gb Non-MaxQ and cooled with Liquid Metal. I have overclocked the GPU to 100/500Mhz Core/Memory Clock and got a 12% increase in performane. The temps are fine, maximum was 80C(just peak, average was 72C) on both GPU and CPU and that was on that poorly optimised AC Odyssey with Very High Preset. Considering that I still got room for overclocking further, I decided to do it. One problem: Even if I set the core clocks at 200Mhz for example, with the RivaTune Statistics and Afterburner will not get over 1900Mhz which was already maximum core clock with 100Mhz overclock. Now comes the question: Is my GPU power throttling? (If it's called like that) and what can I do to get rid of it to increase the core clocks more. And I thought of getting a more powerful charging brick (mine is 20V 170W) from Y920 (which has 20V 230W) and disconnect the battery from the laptop so I won't damage it. It should work or I am just talking BS with this idea? Thanks!
what software did you use for monitoring and overclocking the GPU?
Desktop benching:
I used the MSI Afterburner to monitor the temps and clocks in real-time. Also HWInfo64 to see the maximum after exiting the games. Only the AC odyssey is killing my laptop in temp reaching 80C maximum. Others don't really get even at 75C.
then go to the settings menu and enable voltage monitoring. When you overclock more you should see decrease in operation voltage. Make sure the driver is up to date
Desktop benching:
