Im trying to overclock my ryzen 5 1600 in bios to 3.8Ghz at 1.33V but everytime i do the cpu under clocks itself to 1.4GHz at 1.1V, its not throttling itself because it stays stuck at those clock speeds and voltage. Im using a Gigabyte ga-ab350-gaming motherboard.
I turned off AMD Cool n Quiet and Precision Boost
My Bios is at version F23
Overclocking works on Ryzen Master
Main Desktop: CPU: Intel Core i7-12700K ~ GPU: Gigabyte Radeon RX 6800 GAMING OC 16GB ~ RAM: Corsair Vengeance LPX 64GB DDR4-3200 ~ Mobo: ASRock Z690 Steel Legend
Storage: Crucial MX500 1TB , WD Black SN770 2TB M.2, KingSpec XG 7000 4TB M.2, 8TB WD Blue WD80EAZZ HDD ~ Case: Corsair 4000D Airflow ~ Cooling: Corsair iCUE H100i RGB PRO XT Liquid CPU Cooler ~ OS: Windows 11 Pro
https://linustechtips.com/topic/1116639-ryzen-5-1600-overclocking-issues/
Reset your BIOS setting and try to change CPU Freq by 3.6 and leave voltage to stock. IF it works, change the CPU Freq again until it requires a voltage increase.
Ideally, you dont want to jump to that Freq and Voltage without doing tests, since not all chips are made equally.
Ryzen 5 1600 | Gigabyte GA-AB350M-Gaming 3 | Team Elite TForce Delta RGB 2x8 16GB 3200mhz | Gigabyte GTX 1060 6GB AORUS | Fractal Design Arc Mini R2 | 2 1TB WD Blue | Wester Digital Blue 3D NAND 500GB | SeaSonic M12II 520W 80+ Bronze | CoolerMaster Hyper 212 Led Turbo | ASUS VG248QE | Rakk Kimat XT | Logitech G502 HERO | Massdrop x AKG M220 Pro | V8 Soundcard | BM800 Condenser Mic | Logitech C310
I managed to get a stable overlock of up to 3.7GHz on stock, but once i change the voltage in bios it gives me the same issue.
That what they called "Silicon Lottery". Since not all chips are made equally, some will get a higher clock speed with decent voltage, but some will get a certain limit on clock speed just like yours. If you can't increase more on your chip, then you should stick to what you have now.
IMO, i don't see any difference when i overclock this chip, which is why until now, i'm only using stock speed and i only overclock my RAM to 2700 (from 2400). and it seems that this chip is totally not designed to be OC'd, except if you will get the X variant or a much newer generation.
