lag prblmz r probly iz cuz ur rowter. reinstal them drivrs
| Case: NZXT Tempest 210 | CPU: Intel Core i5 3570K @ 3.9 Ghz | GPU: ASUS ROG STRIX GTX 1070 | RAM: Crucial Ballistix Tactical 8GB |
| Mouse: Zowie FK1 | Monitor: Acer 21.5' | Keyboard: CoolerMaster Stealth w/ Brown Switches |
#KilledMyWife - #LinusButtPlug - #1080penis
https://linustechtips.com/topic/111649-bf4-lag-problems/#findComment-1492604
Hey guys I have serious problems when I play the game  since I installed amd 14.1 beta drivers .Can I install the previous drivers again?Because I tried but I still have the 14.1version which is a big fail.
I literally just finished rolling back to 13.12 due to all the performance issues in 14.1 beta.
Just uninstall from add/remove programs. Reboot. Then install 13.12 from scratch.
https://linustechtips.com/topic/111649-bf4-lag-problems/#findComment-1492659
Thank god its so easy now. Before it used to need uninstalling every piece of software, deleting folders, clearing registery and unintalling driver from device manager. Oh wait, I did almost all those last time my driver installation failed.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/111649-bf4-lag-problems/#findComment-1495617
