Pi-Hole as LAN DNS for custom Hostnames
Hello there,
I need help using pi hole for making custom hostnames for lan PCs and VM.I have a lot of stuff in VMs,2 openwrt aps and a couple of server... How can i set it up because i know pi hole as DNS can make this possible.Example 192.16.0.11→pc.local...Please make so that a stupid person like me can understand it
NOTE!!
I know i should be able to add this into /etc/hosts which works exactly half of times and takes a long time to respond...
Short ping session↓
C:\Windows\system32>ping pc.local -t
Pinging pc.local [192.168.0.11] with 32 bytes of data:
Request timed out.
Reply from 192.168.0.11: bytes=32 time<1ms TTL=128
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.0.11:
Packets: Sent = 26, Received = 14, Lost = 12 (46% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
you can see this is the problem and i want it to work perfectly so i can stop using and getting confused by plain ips.PLEASE HELP!!
22 minutes ago, YouDontHaveToKnow said:
Hello there,
NOTE!!
Short ping session↓
  Hide contents
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
I can’t answer in relation to doing this with pihole, but how your computer resolves the IP should have nothing to do with pinging it. You can see at the start of the ping process, it first determines the IP, and from that point onwards the process uses that IP - it never looks up the hostname again.
to test this, run these at the same time in different windows:
ping pc.local -t
ping 192.168.0.11 -t
and I’m sure you will get the same packet loss in both at the same time.
Based on the pattern you are seeing in the ping responses, I would suspect either
a) a loop in your network
b) two devices both using the IP 192.168.0.11 (an IP conflict)
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
13 minutes ago, Electronics Wizardy said:
Do you get the same ping isue if you just ping the ip, normally if you have pings dropping its not dns.
it seams when i ping localhost,192.168.0.11 or pc.local from the server it works fine but trying to ping from any other pc it behaves the way i describe
ping pc.local -t
b) definetlly not i know something about networking
a)how would i check?
Then its probably not dns, and probably something else on the network.
Whats your network layout? How are you connected. Try different cables
they are both straight to router with the same cable for years
i mean beafore the pihole it all worked fine
if you remove pihole, can you ping normally again?
actually no
8 minutes ago, YouDontHaveToKnow said:
actually no
what is your network setup? Try different cables? What switch? Can you ping from switch without error?
They both go to the sam routher with a short CAT 6 cable...Well never beafore have i just pinged it for no reason so it could have been messd up science forever?
i have tried to ping another pc boom worked prefectly 0 packet drops
i will try to reboot the other pc because its my main torrent downloader so it works 24/7
it works afer reboot let me introduce pihole to my network family again
it now dosent want to ping pc or pc.local here is my /etc/hosts file:
127.0.0.1       localhost
::1             localhost ip6-localhost ip6-loopback
ff02::1         ip6-allnodes
ff02::2         ip6-allrouters
127.0.1.1       home
192.168.0.11    pc
other pople say this setup should work but for me it dosent
on my windows server(the pc.local pc) and my windows laptop(the ping machine) are both configured with 192.168.0.16 primary dns(pihole,static) and 192.168.0.1 secindary(my router)
could it be because i have to setup dns on every device because my router disent support ustom DNS,also ad blocking with this setup works perefetly
127.0.0.1       localhost
127.0.1.1       home
192.168.0.11    pc
You can setup your own dhcp server if you want to set your own dns.
Do the pings work now?
if the pings are failing, its not your pihole, its something else with the network.
Can you show a network diagram?
I was sleeping so sorry here is the Paint diagram(dont cringe)
What 2 systems are pinging?
Try directly connecting the systems with a cable, does the issue persist?
sorry for late reply...After forking around i just found the easist way to get it to work is if I setup pihole as DNS and DHCP because i cant change the dns server on my router.Now it works perfectly. instant hostname lookup and  <1ms for ping
Two system were the win server and my laptop.Now that i have learned i think when i changed the DNS manually it didnt pick up my changes right away after disabling my routers DHCP and setting pihole as dhcp server and rebooting every device.All of them picked up the new confings and with ipconfig/all they all used the piholes Ip as DNS.I am using 1.1.1.1 as the upstream dns on pihole
