If you're using it for gaming in FPS shooters and other games that would benefit from high refresh rate. Get a 1080p 90Hz at least(I'd recommend 120Hz though). LTT has put up great budget monitor reviews recently.
Upgrading GPU is a good idea. RX570 or 1660TI is a good idea. You could go for a more expensive GPU but next upgrade would be to save up for mobo and CPU.
