Need Help/Suggestions for case fans
So i just brought thermaltake vies 37 argb case. Very good case but the fans are bothering me. I cant adjust the speed at all and after some research i found out its by design so i need to change them. There are 2*200mm fans at the front of the case and 1*140mm at the back. I want to get new rgb fans in there that i can control both the rgb and fan speed. Which set do people recommend for this one?
https://linustechtips.com/topic/1114989-need-helpsuggestions-for-case-fans/
As far as I know, they only 200mm RGB fans out there from a somewhat reputable brand come from thermaltake and cooler master. I'm sure both are fine, so pick whatever looks nicest and whatever has software you find the least offensive.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
