Help with NVME
Go to solution Solved by Tan3l6,
1 hour ago, Okcej said:
Sorry for the late reply guys. I really appreciate all of your suggestions. After doing some research, these 2 below are my options (converted the price from PHP to USD):
Crucial MX500 500GB = 92.15 USD
Samsung 860 EVO 500GB = 88.21 USD
I'd go with Samsung, just because it's cheaper.
Also it has also better endurance - 300TBw vs 180TBw
Hi!
I just recently learned about nvme and I’m wondering if it’s compatible with the PC I bought from a friend. I really don’t have knowledge about gaming systems. Here are the specs:
Ryzen 3 1300X
MSI A320M Pro VD/S
Hyper X Fury 2x8 GB DDR4
RX 580 4GB
1TB HDD
If in case it doesn’t support nvme, please let me know the cheapest but good motherboard I can buy. Thanks.
https://linustechtips.com/topic/1114947-help-with-nvme/
Doesnt have an m.2 slot to begin with.
What country?
You dont "need" Nvme tho. Sata is just fine.
https://linustechtips.com/topic/1114947-help-with-nvme/#findComment-12977390
No, your motherboard do not have a slot for Mvne
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1114947-help-with-nvme/#findComment-12977392
3 hours ago, Okcej said:
I’m from the Philippines. Could you recommend a nice SATA for me?
Best SATA SSDs
I own Samsung and SanDisk. But if you go with Crucial, it's #5 on the list.
"You're my dearest friend & my love. You lit my path through darkness & I'll stand with you...to whatever end." -Leliana (DAO).
https://linustechtips.com/topic/1114947-help-with-nvme/#findComment-12977873
I'd rather more trust that list - https://www.ign.com/articles/the-best-ssd-for-gaming
Gaming site but at least they aren't promoting QLC SSD as best option.
Actually for a budget build QLC isn't a bad choice, just have to check the best price/quality.
But prices in the Philippines are probably much different than in EU or USA.
Crucial MX500 and Samsung 860 EVO are both solid choices though.
Pax vobiscum
https://linustechtips.com/topic/1114947-help-with-nvme/#findComment-12977893
13 minutes ago, mcbaes72 said:
Best SATA SSDs
uhhh.......... i dont think that is a very reliable site when it comes to SSDs.........
dont think thats the greatest one either since they consider 260$ as affordable for 1 tb drives.........
https://linustechtips.com/topic/1114947-help-with-nvme/#findComment-12977918
@GoldenLag Maybe this one then - https://premiumbuilds.com/ssd/best-ssds-for-gaming/  At least I agree in most cases with those options/categories they've selected, more than in previous links.
But prices tend to differ in other regions. So OP should do some research self.
Pax vobiscum
https://linustechtips.com/topic/1114947-help-with-nvme/#findComment-12977939
he should look for himself indeed.
that site seems more genuine looking at the suggestions. at least more up to date with the current US market.
https://linustechtips.com/topic/1114947-help-with-nvme/#findComment-12978025
Pax vobiscum
https://linustechtips.com/topic/1114947-help-with-nvme/#findComment-12990418
