10 hours ago, Malachi Groves said:
So i did a dry run for a x570 board with a ryzen 5 3600x and 16 gb’s of ram. After power on it sparked from the usb c port in the rear io and didn't post, after i turned the power off it continued to spark until removing the cable. Help
There's a good chance something got damaged. Stop using the port immediately, and test the board without it. See if it boots, if not, you need to RMA it. Never continue to use a product if it sparks (unless it's designed to under normal operation).
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
Just because it may seem like magic, I'm not a wizard, just a nerd. I am fallible.
Use the quote button or @<username> to reply to people | Mark solved troubleshooting topics as such, selecting the correct answer, and follow them to get replies!
Community Standards | Guides & Tutorials Troubleshooting Section
