ASRock x570 Extreme4
Dear Linus Tech Tips forum,
Recently I rebuilt my system to include a Ryzen 3700x with an ASrock x570 Extreme board as part of doing that I reinstalled windows and I was installing motherboard drivers specifically for the RGB on the board/cpu fan and upon installing and running ASrocks polychrome software my system freezes and locks up requiring me to force shut down my system restarting. I am very confused as to why my system might do this, I downloaded that version of polychrome from the motherboards page on ASrocks site. Any fixes or solution to help me fix this issue would be greatly appreciated.
Thanks in advance,
Aiden aka ShelterMan
is the bios up to date?
Desktop benching:
I just updated the bios and tried reinstalling polychrome and the same thing happened
Did you just search "Polychrome" and downloaded from the main link, or downloaded from the link in the board's support page? Sometimes the versions you get from different sources are different
Desktop benching:
I went to the motherboards main page on ASrocks website and went to the downloads section and downloaded polychrome
I guess the software is already outdated then. The bug you see could be caused by Windows.or even BIOS updates over time. Asrock's RGB sync ecosystem hasnt really taken off after so long
Desktop benching:
