Hi All,
So NBN is now installed in my area (Australia's crap new "state of the art" 100mbps internet system) and as a part of swapping across to it I have to ditch my old analogue phone as only VOIP is usable on the new network. However being a gamer I like to have my model close to my PC but don't want to have to connect my home phone to the modem in my computer room. So I was wondering if anyone had any ideas on how I can get around this?
Telstra (one of Australia's big internet providers) offers a product they call the Telstra Voice Extender https://www.telstra.com.au/content/dam/tcom/personal/home-phone/pdf/TVE-User-Guide-Final.pdf and this works by connecting your phone wirelessly to your telstra modem, however I am not using telstra for my internet and phone and instead will be using iinet.
Also ideally I don't want to plug the existing wireless phone into the router and leave the handset in the kitchen as my partner always loses the phone.
The modem router provided by iinet is the tp-link Archer VR1600v https://www.tp-link.com/au/service-provider/xdsl/archer-vr1600v/
Does anyone know of any other options that work like the telstra voice extender that will work with my modem? Or is there some other style of adapter like one of the range extender powerpoint adapters that supports voip or do I need to buy a wifi enabled voip phone that only needs to be connected to a powerpoint and to the wifi? Or are there any better suggestions? Oh and preferably not too expensive as I am a university student
Thanks heaps for any help,
Darkclone :)
https://linustechtips.com/topic/1112027-nbn-voip-phone-question-yes-very-australian/
Wait? You're actually getting the full 100mbps? Lucky!!
Just run an ethernet cable from the modem to the phone. Presumably there's already a cable in the wall going to where the phone is for the existing phone line?
Or have the modem near the phone and run ethernet to the PC. Whichever is easiest depending on how the house is wired.
Thanks for the reply, the issue with cables is that my disabled mother in law lives with me and the way the house is setup I would only be able to run the cable on the floor. NDIS already growled at me for having done so in the past and the way the house is setup the only other way I could do it would be to tape a cable to the wall and I dont want to do that haha.
Thats wrong, you plug the analogue phone into the new modem as the router does the voip translation.
