So I got a new GPU today (AMD Radeon RX 460 4gb) for my pc, and after installing it and a new power supply, I booted up the machine and found that my second monitor that has a VGA connector does not display anything other than a black screen.  I tried restarting my pc several times, as well as unplugging and re-plugging the VGA connector.  That did nothing to fix the issue.  Before i got the new GPU this issue had never happened before.  Any help is appreciated.
Thanks
What cable are you using for the VGA connection?
Primary PC:
2 minutes ago, avenreptiler said:
a VGA cable?
What model 460 do you have that uses a VGA port?
Primary PC:
6 minutes ago, avenreptiler said:
The VGA is connected to the motherboard.  Only my primary monitor (DVI) is hooked up to the gpu.
so the GPU is probably taking priority over the integrated graphics. What CPU do you have?
Primary PC:
On 10/9/2019 at 11:37 AM, zinton said:
ditto ^
many new gpu's dont have a vga so you may need an adapter aswell
yeah, that's what i've decided to do after doing some more research.  seems like an adapter will work.  thanks.
