So a while ago I bought a 2070super and a new 144hz monitor (with freesync)
with g sync enabled whenever i alt tabbed out of the game its like my monitor would change the resolution about 3 or 4 times, any browsers i had open would shirk and appear in the top left of the screen. Id get that windows notification telling me about the g sync settings pop up too. When i went back into the game it would do exactly the same thing and then minimise it making me have to try and open it about 3 more times before it would stick
I turned g sync off and its still doing this
i have no idea what its doing or why its doing this
any ideas?
https://linustechtips.com/topic/1111514-g-sync-problems/
borderless windowed mode would solve this problem in games that offer it, and also you can use a program called "borderless gaming" to apply borderless windowed mode to almost every game.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1111514-g-sync-problems/#findComment-12949028
What monitor is it? Some monitors also require you to manually enable FreeSync on their menu.
Might be a better option to DDU in safe mode and start new indeed... download the driver beforehand then DDU in safe mode and when you reboot don't enable internet so Windows Update doesn't get in the way... only then install the latest driver.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1111514-g-sync-problems/#findComment-12949033
i have an acer xf240h
i have looked through the menu and cant seem to find any setting for it
https://linustechtips.com/topic/1111514-g-sync-problems/#findComment-12949038
after you enable freesync on the monitor...you need to enable g-sync...
then:
you need to make sure the game and nvidia resolution are set to 144hz...
  • CPU
    AMD Ryzen™ 7 5800X 4.7Ghz
  • Motherboard
    MSI MEG X570 ACE
  • RAM
    G.SKILL Trident Z Royal Series 32GB (2 x 16GB) F4-3200C16D-32GTRS
  • GPU
    GeForce RTX™ 3060 EAGLE OC 12G (rev. 2.0)
  • Case
    Cooler Master MASTERBOX MB520 ARGB + Cooler Master MasterFan MF120R ARGB
  • Storage
    ADATA XPG SX8100 2TB PCIe Gen3x4 M.2 2280 SSD
    ADATA LEGEND 960 4TB PCIe Gen4x4 M.2 2280 SSD
    ADATA Ultimate SU800 2TB 2.5" SSD
    Crucial BX500 2TB 3D NAND SATA 2.5-inch SSD
    Toshiba X300 4TB 7200 RPM
    TOSHIBA MG06 (MG06ACA10TE) 10TB 3.5 Inch 7200RPM Enterprise SATA Hard Drive
  • PSU
    Cooler Master MWE GOLD 750 FULL MODULAR
  • Display(s)
    Acer KG271B Gaming Monitor (HDR Ready 27" 1920X1080 240Hz)
    MSI PRO MP241
  • Cooling
    Cooler Master MASTERLIQUID ML240R RGB
  • Keyboard
    MSI Vigor GK80 RED GAMING KEYBOARD
  • Mouse
    Razer Naga Hex Wraith Red Edition Wired Laser Mouse
  • Operating System
    Windows 11 Home
  • Router
    tp-link EB810v BE22000 Tri-Band Wi-Fi 7 VoIP Router
    Asus ROG Rapture GT-AX 11000
  • Network Card
    tp-link Archer TBE550E BE9300 Wi-Fi 7 Bluetooth 5.4 PCIe Adapter
https://linustechtips.com/topic/1111514-g-sync-problems/#findComment-12949045
This is generally correct behaviour when u do exclusive full screen game on windows. Some older title does it very strict and would have issue alt tabbing. Even newer game like Apex would crsh if u alt tab too much. Fix would be turn off ‘exclusive’ full screen, and also play on resolution same as monitor resolution.
https://linustechtips.com/topic/1111514-g-sync-problems/#findComment-12949055
then i have no idea why...mine had this issue when i did not set them to same frequency..alt tabing will need to refresh...
oh ya..everything is set to the same resolution right?
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111514-g-sync-problems/#findComment-12949058
Never had a notification mentioning gsync on my pc ever.
But I did have a issue about tabbing out and it would change the refresh rate on me. Updated to a newer driver and it seemed to stop. It was months behind as I don’t play new games.
https://linustechtips.com/topic/1111514-g-sync-problems/#findComment-12949426
