Metal sound on keyboard - ping noise?
On my keyboard with gateron red one letter got some metal resonance sound when typing. Is it possible that this sound will go away? Does that comes under warranty?
It sound something like this: https://www.youtube.com/watch?v=yQ_L3WnAnQk
from 12 seconds.
Would it be stupid to buy 1 o ring just for one key? That would help? On aliexpress/ebay I can find only o rings for chery mx but I have gateron switches. Will they fit without problems?
https://linustechtips.com/topic/1111447-metal-sound-on-keyboard-ping-noise/
3 minutes ago, Arika S said:
o-ring wouldn't help. If it sounds like the video you linked, it's possible the spring is the wrong size and isn't just pushing the key back up into place, it's too tight so it's literally springing back with more force than necessary.
See if you're able to buy a single replacement switch and swap it out with the problematic one. Looks like they just pop out similar to cherry's
It is Steelseries apex 7 keyboard under warranty, not hot swap keyboard. So sound won' t go away, can't RMA it, I must live with that?
You could desolder a key you don't use (Scroll Lock for example) and replace the R switch with that one..
Otherwise it's probably an issue you'll just have to deal with, I'm afraid.
1 hour ago, Arika S said:
Why not? It's a defect
I sent a mail to Steelseries but as far as I read some threads about that problems everybody say that is not for RMA, tha I will hava to live with it??
@minibois
I won't solder anything, it is a month old keyboard, I never done anything like that. I sent a mail to Steelseries support to see they advice
Your springs are pinging and resonating with the metal plate. Pretty much all keyboards will do this to some degree. You can fix it. Lube the springs and install felt or foam sheet sound dampening under the PCB. See the guide in my sig.
  • 10 months later...
I know it’s been a while, but did you return the Apex 7 ?
I ask because I’ve just returned an Apex Pro because of this issue, and am curious if you got a new Apex 7 or went for something else that doesn’t exhibit as much ‘ping’.
