Hi everyone
i just build my pc and when I  I boot up the computer, there is no signal displayed onto my monitor. CPU LED stays lit for half a second then goes away, and then DRAM LED lit up few seconds and repeat. I tried single ram stick, alternating ram slot and ram stick nothing works. everything else seem working properly every fan spinning, water cooler working, VGA and ram RGP also lit, and weird thing is ram rgp light up without turning on, also the monitor worked perfectly with my laptop. Can some one please help?
my spec:
CPU: Ryzen 5 3600 6 core AM4 3.6GHz CPU with Wraith Stealth Cooler
Mobo: Gigabyte X470 Aorus Ultra Gaming Socket AM4 ATX Motherboard
(rev.1)
SSD: Samsung 250GB 970 EVO Plus M.2 NVMe SSD
Ram: Corsair 16GB (2x8GB) CMW16GX4M2C3000C15 DDR4 3000MHz Vengeance Pro RGB
GPU: Gigabyte GeForce RTX 2060 Gaming 6G OC Pro Graphics Card
PSU: Corsair RM550x 550W V2 Power Supply Fully Modular 80 Plus Gold
HDD: Western Digital Blue 1TB SATA3 HDD 64M Caviar Blue WD10EZEX
It said that my mobo is ryzen 3000 ready on the website but i dont know does it need bios update to ready or it's already ready or ryzen 3000. Also i could find my ram in ram support list of the mobo. Is it a huge problem?
https://linustechtips.com/topic/1110804-pc-wont-post/
X470 might need a BIOS update to run a Ryzen 3000 series CPU.
Main Rig:-
Server:-
https://linustechtips.com/topic/1110804-pc-wont-post/#findComment-12943506
  • 1 month later...
Did you find a solution to this because I am having the same issue with a ryzen 2600 with a aorus M board. I found that if I pull the NVMe (SN500 WD Blue), which should be compatible with this board according to the manufacturer, when I do that, it will post. I've updated the bios and still nothing. Would be interested if any of you found a fix.
https://linustechtips.com/topic/1110804-pc-wont-post/#findComment-13089960
