Editing this to reword it as it was awfully structured. I have three monitors. Two Acer G226HQL's, that only accept vga and dvi-d. Both are 60hz, 5ms panels. My main monitor is a Acer GN246HL, a 144hz, 1ms panel with HDMI, DVI-D and vga. My card is a 2070 super, from a 1060 6gb. What cable(s) do I need to continue using all three monitors as well as 144hz? If you could provide links that would be great, I have tried to do my own research and have an idea of what to get but I want conformation like any rational human and don't want to waste any money.
Just got a ROG Strix 2070 Super, and all my current three monitors use dvi. I have two 60hz already with hdmi adapters, but my main monitor is 144hz, and obviously the 2070 super does not have a dvi port. My question is, what cable adapter do I need for this card? My monitor only accepts dvi-d and hdmi, but the two dvi ports are being used by the other two monitors.
https://linustechtips.com/topic/1110620-what-cable-do-i-need/
You don't want adapters but rather a DisplayPort to Dual Link DVI-D cable like these:
The cable has both ports already and will work flawlessly, even sound transfer should work.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1110620-what-cable-do-i-need/#findComment-12941923
10 minutes ago, mariushm said:
Not much you can do.
Most HDMI or DisplayPort to DVI adapters are DVI single link, meaning you're capped to 1920x1200 60 Hz on the DVI output.
Surely they can just use one of the HDMI ports for the main monitor then a DP to DVI-D for the other monitor.
I'm kinda surprised there is a 144Hz monitor WITHOUT DP.
https://linustechtips.com/topic/1110620-what-cable-do-i-need/#findComment-12941928
Yeah these are one of the first 1080p144hz monitors way back when LCD panels were starting to replace good and old CRT... they really only had Dual Link DVI to work with since first HDMI revisions were locked to 1080p60hz and DisplayPort took a little to take off.
Personal Desktop":
https://linustechtips.com/topic/1110620-what-cable-do-i-need/#findComment-12941940
Acer GN246HL. Got it as soon as I built my new PC and I had a $1k budget for the whole thing, including the desk. Got it for around $180, not my best investment but 14 year old me was impatient.
https://linustechtips.com/topic/1110620-what-cable-do-i-need/#findComment-12941962
Do you have a link to one of these?
https://linustechtips.com/topic/1110620-what-cable-do-i-need/#findComment-12941963
The "that cable" logo in the corner is a hint.
Anyway... just because the DVI connector has all the pins in it, doesn't mean the cable is actually DVI-D Dual Link.
This 8$ cable isn't, yet it has all the pins:
Amazon.com: BENFEI DisplayPort to DVI Adapter, Dp Display Port to DVI Converter Male to Male Gold-Plated Cord 6 Feet Black Cable for Lenovo, Dell, HP and Other Brand: Electronics
So unless the description of the product really specifies, I'd say avoid spending your money
Even active converters may not do more than 60 Hz.
https://linustechtips.com/topic/1110620-what-cable-do-i-need/#findComment-12942007
https://www.newegg.com/p/N82E16882422117?Item=N82E16882422117
I have personally tested this cable, and it 100% works.
Oops, sorry... That's for HDMI not DP... Here's one...
https://www.newegg.com/white-coboc-3-ft-dvi-cables/p/N82E16882678032?Item=N82E16882678032
Benefit of this listing is that it tells you the requirements to make these type of cables work. (a DP++ port that allows for HDMI signals to be transmitted over DP cabling)
Edited by BTGbullseye
Wrong link.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1110620-what-cable-do-i-need/#findComment-12943655
