whats you budget for each
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/111058-need-webcam-and-mic-help/#findComment-1484021
Go with the Logitech C920 and a Blue Yeti or a AT 2020 XLR version if you are going to do a XLR setup.
Current System: CPU - I5-6500 | Motherboard - ASRock H170M-ITX/ac | RAM - Mushkin Blackline 16GB DDR4 @ 2400mHz | GPU - EVGA 1060 3GB | Case - Fractal Design Nano S | Storage - 250GB 850 EVO, 3TB Barracuda | PSU - EVGA 450W 80+ Bronze | Display - AOC 22" 1080p IPS | Cooling - Phanteks PH-TC12DX_BK | Keyboard - Cooler Master QuickFire Rapid(MX Blues) | Mouse - Logitech G602 | Sound - Schiit Stack | Operating System - Windows 10
The OG System: I3-2370M @ 2.4 GHz, 750GB 5400 RPM HDD, 8GB RAM @1333Mhz, Lenovo Z580 Laptop (Ubuntu 16.04 LTS).
Peripherals: G602, AKG 240, Sennheiser HD 6XX, Audio-Technica 2500, Oneplus 5T, Odroid C2(NAS).
https://linustechtips.com/topic/111058-need-webcam-and-mic-help/#findComment-1484033
Logitech C920 might be a bit overkill if you are only starting. Usually when you do streaming you're not going to have yourself in full 1080p mode. C270 or C525 would be better starter options.
For a microphones, most people will recommend Blue Snowball or Yeti (Yeti being the better one). My own recommendation would be Audio-Technica AT2020. I find it to be the best of its class. Another option is Samson Meteor (I'd rank it somewhere between Snowball and the AT2020).
https://linustechtips.com/topic/111058-need-webcam-and-mic-help/#findComment-1484199
I used the RODE Podcaster as my microphone but it can take up a lot of space considering it needs a mount. For a desktop friendly solution I would recommend the Blue Snowball and Yeti. The AT2020 would be the same as the RODE Podcaster and I've heard sound comparisons, I'd recommend the AT2020 over the RODE Podcaster if you have the space for it.
https://linustechtips.com/topic/111058-need-webcam-and-mic-help/#findComment-1487479
