That's to be expected since you downgraded your motherboard.
The Gaming Plus alongside couple other MSi branded X570 boards are the worse available X570 motherboards on the market on the regards of their VRM and Power Phasing layouts:
While the Gaming Plus in specific wasn't tested it should fall between the Edge and Pro Carbon.
With that said, make sure your CPU cooler is properly mounted and that your VRM is receiving all the airflow it can get.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1110573-running-hotter/#findComment-12941555
x570 board for a 2700?  you could have gotten for example a b450 with good VRMs etc, such as the MSI mortar or tomahawk, and for less money. Unless you wanted the I/O of the x570 or for a future build of course?
Anyway, regardless, there shouldn't be a 20C difference in cooling your CPU from one motherboard to the next.. there must be some reason behind it. have you checked the CPU fan curve? did you change the case/chassis?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1110573-running-hotter/#findComment-12941695
It's probably just a voltage and clockspeed issue, check voltage in the UEFI it may be overkill for the CPU, lower clockspeed to 4GHZ and Vcore to 1.33-1.35 and see if temps come down. My 2700 is running about 5-7 degrees over delta with a 240mm AIO at idle with 4.125ghz static and 1.35 volts Vcore.
It may also be a thermal paste issue.
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
https://linustechtips.com/topic/1110573-running-hotter/#findComment-12941791
