A few years ago, my pc crashed and my gpu has been bricked ever since. I have 2 970s so it's been sitting on my shelf for years and I've been using my other 970. I've tried many things to fix it like using a different pcie port and cables, removed drivers and reinstalled, flashed gpu bios with my other working 970s bios and tried flashing with the most up to date bios online. and also flashed the mobo with the most recent version. The gpu in device manager comes up with "Windows has stopped this device because it has reported problems. (Code 43)." In the events tab is comes up with "Device PCI\VEN_10DE&DEV_13C2&SUBSYS_85081043&REV_A1\4&33e4407a&0&0058 requires further installation." (See imgur link). Interestingly enough, my other working 970 also comes up with "Device PCI\VEN_10DE&DEV_13C2&SUBSYS_85081043&REV_A1\4&2534e90f&0&0010 requires further installation." in the events tab. so I don't know whats up with that. When I looked at both gpus in GPU-Z there are a few inconsistencies. (noted in red, see imgur link). When the pc is turned on, the gpu doesnt output and the fan spins at max speed or sometimes not at all. (see video). Any help on fixing this gpu would be appreciated.
pc specs
gtx 970 asus strix 4gb
8gb ddr3 1333mhz ram
fx-8350 4ghz
gigabyte 990fxa-ud3 rev. 4
https://imgur.com/a/RAcGBYR
https://imgur.com/a/VYu5wbv
https://linustechtips.com/topic/1110037-help-gtx-970-bricked/
Sounds like a dead GPU to me, if this happened a few years ago you should of sent it in when it was still under warranty and gotten a replacement.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1110037-help-gtx-970-bricked/#findComment-12936657
