https://linustechtips.com/topic/1108183-pc-build-help/
3 minutes ago, Ah2004 said:
Total (before mail-in rebates)
I should think you could get a larger SSD for only a few dollars more.
I'd also get a more powerful power supply, but that's just me planning ahead.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1108183-pc-build-help/#findComment-12922488
i think you should add more space to SSD like around 512GB. intel 660P also good.
and also its not worth to buy RTX non-super. buy the super version and if you could go to 2070 Super. the alternative is 5700XT but no ray-tracing
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1108183-pc-build-help/#findComment-12922496
oh yeah thx for mentioning i totallly forgot i already have a 1tb ssd so im good on storage
https://linustechtips.com/topic/1108183-pc-build-help/#findComment-12922500
also can you explain what this means?
https://linustechtips.com/topic/1108183-pc-build-help/#findComment-12922501
The super version, 2060super 20170super etc. offer you much more performance for money. second, the 2060 very weak for ray-tracing most of people would go at least 2070Super for minimum-ray tracing GPU. third if the 2070Super it too expensive, then you can go with NAVI 5700XT but the AMD cards cannot do Ray-tracing
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1108183-pc-build-help/#findComment-12922509
sorry i meant this↓↓↓↓↓↓↓↓↓↓↓↓
https://linustechtips.com/topic/1108183-pc-build-help/#findComment-12922517
when u put M.2. you SATA slot its reduced. so let say the SATA slot is 6 then you put 1 M.2 SSD. your Available SATA slot now its 4. because it use same bandwith SATA - M2
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1108183-pc-build-help/#findComment-12922578
oh okay so iam assuming not much to really worry about. thx
https://linustechtips.com/topic/1108183-pc-build-help/#findComment-12922585
are you just gaming with the rig?
https://linustechtips.com/topic/1108183-pc-build-help/#findComment-12922612
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($260.50 @ Vuugo)
Motherboard: MSI B450 GAMING PRO CARBON AC ATX AM4 Motherboard  ($169.99 @ Canada Computers)
Memory: Team Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($79.99 @ Newegg Canada)
Storage: Lexar NM600 480 GB M.2-2280 NVME Solid State Drive  ($64.99 @ Canada Computers)
Storage: Western Digital RE 2 TB 3.5" 7200RPM Internal Hard Drive  ($51.53 @ Amazon Canada)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  ($556.99 @ PC-Canada)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  ($89.99 @ Corsair)
Power Supply: Rosewill Capstone 650 W 80+ Gold Certified Semi-modular ATX Power Supply  ($99.99 @ Newegg Canada)
Total: $1373.97
Generated by PCPartPicker 2019-09-26 22:11 EDT-0400
https://linustechtips.com/topic/1108183-pc-build-help/#findComment-12922622
