I found build with r5 3600 and rx 5700xt (reference one) for I guess decent price.
The question is that is there is any good cooling solution that I could use if I bought this pc idc some aio. (would use it for home server later on)
I'm also planning to do custom loop sometime but now there is not much money to spend on that.
https://linustechtips.com/topic/1108072-cooling-down-rx-5700xt/
I had significant success with just putting good thermal paste on instead of the thermal pads... Took it down by 12°c on average, and that's comparing a significant undervolt and underclock to a significant overclock. (should get more than 20°c comparing the same clocks)
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1108072-cooling-down-rx-5700xt/#findComment-12921598
