A week ago I stared hearing my Hard drive (on my pc) to spin a lot faster than usual even when in idle I can hear it....Just to be clear I dont have any problems when it comes to noise after all my pc has 3 fans including the cpu cooler and a hard drive as well as an ssd and it is a mini itx build but thats besides the point the thing is that my hard drive is so loud that even when I have a video playing I can hear it over the voice of the guy I am wathcing. Also sometimes it spins really fast and it sounds like a jet !! The drive is 4TB Western Digital and I got it 2 months ago from my warranty because my other drive malfunctioned and wester digital sent me a new one. I dont know what to do is my disc bad or it is just the fact that it is really loud all the time
Thanks in advance!!!!!!!
https://linustechtips.com/topic/1107043-hard-drive-problems/
Umm, a hard drive can't really spin faster or slower.
It either spins at a fixed rpm (most common rpm's are 5400, 5900 and 7200 iirc) or it's idle which turns off the motor.
So it's either a bit loose causing it to rattle and end up being VERY loud because the case usually amplifies the little bit of shaking from the hdd to something a lot worse.
What I would do is take the HDD out and put it on a cardboard box but leave it connected and see if the loud noise is away or is actually from the HDD itself.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/1107043-hard-drive-problems/#findComment-12912998
I did that already by just having the hdd in my hand and it still vibrated a lot and even when i touch it while in the case it was vibrating like crazy however when i had it in my hand I realized that one of the 4 or 5 black circles on the drive (i dont know what they do they look like stickers) is non existent. And also i forgot sometimes there is a knocking sound from the drive
https://linustechtips.com/topic/1107043-hard-drive-problems/#findComment-12913005
If you don't have the drive backed up already, back it up NOW.
Jeannie
As long as anyone is oppressed, no one will be safe and free.
One has to be proactive, not reactive, to ensure the safety of one's data so backup your data! And RAID is NOT a backup!
https://linustechtips.com/topic/1107043-hard-drive-problems/#findComment-12913789
I just have games from steam and a couple of documents that I can re-write but why ? Why should I back it up and what does the symptoms that I wrote on my last message mean for the drives life??
https://linustechtips.com/topic/1107043-hard-drive-problems/#findComment-12913919
The symptoms indicate that the drive is probably failing.
Jeannie
https://linustechtips.com/topic/1107043-hard-drive-problems/#findComment-12914927
better get a new Harddisk drive and if you dont want to have a hassle to redownload games from steam, try making a recovery disk of games from steam.
https://linustechtips.com/topic/1107043-hard-drive-problems/#findComment-12915127
Well that doesnt sound very good
And I will try to get a new drive but how do i make a recovery disk from steam??
https://linustechtips.com/topic/1107043-hard-drive-problems/#findComment-12915341
Creating Backup Files
  1. Right-click the game in the Library section
  2. Select Backup game files...
  3. Check the boxes for any other games to backup at this time
  4. Click Next >
  5. Browse to the folder where you wish to create the backup files (the files will be stored in c:\program files (x86)\steam\Backups by default) and click Next >
  6. Select the Backup file name and set the File size for the media you plan to use.
  7. Click Next > to begin the backup process.
  8. Once complete, choose Open backup folder  to move or burn copies of the backup files
Copied from steam support:
https://support.steampowered.com/kb_article.php?ref=8794-yphv-2033
https://linustechtips.com/topic/1107043-hard-drive-problems/#findComment-12917548
